Lady Berkshire movement issue
Submitted by davep on
In trying to fit a donor 6BO movement into a Lady Berkshire case (which formerly contained a quartz movement) , the stem seems too short as the crown is fouling the case even when pulled out . A novice in this area so unsure how stem is removed if indeed a longer version is needed for this particular model . Any advice, pearls of wisdom etc , would be much appreciated
Posted October 10, 2024 - 10:51am
The stem of Your donor movement has been cut to fit the case is was in. Buy a new stem and cut to fit if necessary.
davep
Posted October 10, 2024 - 10:55am
Hi, thank you ,  its the stem removal procedure I am unsure of , I have done it on other movements but not sure with this layout
Posted October 10, 2024 - 11:06am
Back the detent screw off a turn (small screw head near the stem) and the stem should slide out, if not try in 1/2 turn increments until it does.
davep
Posted October 10, 2024 - 11:14am
 of course! , being an absolute novice didn't know were to begin to look , Thanks again.
davep
Posted October 10, 2024 - 11:45am
Yep, that's what I thought , thankyou , bit of a labour of love this one, the first donor movement turned out to be 21 jewels and not 17 , and proper  hands have now been sourced from Perrins,  let's see what's next !
Posted October 10, 2024 - 5:43pm
Crystal specs. are floating around here somewhere, if I recall its 10.1 mm.
davep
Posted October 11, 2024 - 2:47am
Crystal looks ok but thanks, useful info . Have sourced the stem here in the UK so fingers crossed, the crown might be the last thing if it proves difficult to remove .
