what tools are need to remove a small dent from a case
Submitted by Ellierose on
hello i have an old banker 1928, the case has a small dent about a millimeter dia. . i was wondering what tools i could use to remove the dent..i am afaid of making it worse though...i was hoping someone had some tips and hints on removing dents...i would leave it alone but its dead center on the top of the bezel....i just don't want to muck it up....i was thinking maybe some type of dentist picks or something simliar..
simpletreasures
Posted December 27, 2011 - 10:12am
 I wouldn't recommend anything metal. I have used small wooden dowels used in crafts, it all depends where the dent is. You also need to have the front of the bezel resting on wood like a paint stir stick or similar or you'll make the dent worse. Start with light even pressure until you start seeing results. I have used a rubber mallet lightly tapping the dowel directly over the dent. Without seeing what your dealing with it's hard to give better specifics.
Ellierose
Posted December 28, 2011 - 8:36am
thanks for the tip , i haven't been able to comment,been busy...here are some pics of the dent,they are hard to see but its there...the problem is the fact the dent is between the space for the crystal and top of the bezel so its hard to get at..i will try filing down a dowel rod to fit in there...if you hadn't said anything i probably would have used something metal. when i did a search online, i only got repair companies,nothing i could really use...i did some dent repair on cars when i worked at a car dealer,and i used metal rods,,so again thanks for the tip...
Ellierose
Posted December 28, 2011 - 8:52am
well i tried use a dowel rod but i really can't get any leverage on the rod beause of the space i have to work within i'll try to figure something out...the other problem is having the dowel filed down enough to fit in that space and to still have enough power to manipulate the metal....
simpletreasures
Posted December 28, 2011 - 11:02am
In the last pic it looks like there's a dent on the outside of the bezel right near where the crystal sits? If that's correct send me a reply and I might have your fix.
Ellierose
Posted December 28, 2011 - 11:23am
yes that where the dent is..very hard to get too..because you can't really push down on anything being the bottom of the case gets in the way
simpletreasures
Posted December 28, 2011 - 11:40am
Is it a hinged case or can you remove the caseback?
Ellierose
Posted December 28, 2011 - 12:24pm
its hinged
simpletreasures
Posted December 28, 2011 - 12:27pm
Can you get to the area of the damage with the case in the open position?
Ellierose
Posted December 28, 2011 - 2:11pm
somewhat...its kinda easier with the case open
