So I was cleaning a watch and needed to unscrew the crown. Used a tweezers to hold onto the stem and it unscrewed relatively easy.
Now I can't get it to tighten enough for the watch to function again and I'm worried if i Loctite it or something I'lll screw it up for good.
Don't have a screwdriver little enough to get the stem out... maybe if I flatten the head of a needle or something.
Anyway... I'm horrible and hamhandedly breaking stuff when I get frustrated... not on purpose.... more like HULK SMASH... I'm to much of the old school.... oh if it won't tighted just tork on it harder!
How do I tighten this thing?!
Loctite blue will work OK. If you need to once again remove the crown from the stem, the application of a small amount of heat like an alcohol lamp will be sufficient to loosen the loctite. Use a very small amount of Loctite at the movement end threads of the stem just enought to engage the threads of the crown so as not to coat the entire thread.
DONT USE RED LOCKTITE !!!!!!!!!!!!! Every one has some lying around if they fix stuff...stem will break before the red lets go...
And no I havent done this lol but I have broke 5/16 grade 5 bolts before red let go....
I am having much difficulty with the 57 unk waterproof.. cant get to the stem to hold it....
In reply to the crown is on the stem, by shooter144
Shooter
The waterproof ones that have the movement removed from the front usually have split stems similar to the picture below, a bit like a key and key hole. You do not bneed to remove the crown. Simpy pull out to time set positing and you may get a glimpse of it with a loupe, turn it so you can see the slots and then pull the movement out..
