can any give any advice on how to clean watch hands...can you use to clean parts...i have a beautiful ranger with a great dial and and case...but the hands are rotted, i guess that what it is oxidation...does anyone have a good method for cleaning hands...also a rub or polish with adbrasive properties....sorry if these questions are to general but i figure things like this can help other up and coming watchmakers/hobbist
Plastx from Autozone cheap and verry fine abrasive can use on crystal or cases...I use tarnx on the hands...
thank you shooter...i just bought some from my local store...i'm going to try it right now...
In reply to thank you shooter...i just by Ellierose
I use it by hand and with a buffing wheel on a dremel and my small jewelers buffer. Bought the small buffer for like $40 on the bay, pretty stout little machine with variable speed as well !!! www.wellandcanal.ca/salties/lykes/ashleylykes/lykes.htm Uses popular 5 in or smaller wheels with .5 in or less arbor hole ( 4in seems to be most popular avail from most jewelry supply houses like Otto Frei ) It works really well so far on cases and crystals.
